AI0-DD05120-RPSMA Antenna Specifications and
Radiation Patterns
The AI0-DD05129-RPSMA antenna is a dual band sector antenna that provides coverage of
2.3 to 2.7 GHz and 4.9 to 6.1 GHz in a single antenna radome.
The AI0-DD05120-RPSMA antenna attached to a pole
Use the information in the following sections when you plan your antenna
installation.
Table 1. Electrical
| Item |
Description |
| Frequency range |
2.3-2.7 GHz & 4.9-6.1 GHz |
| GAIN, typ. |
2 x 5 dBi |
| VSWR, max. |
2 : 1 (typ. 1.5 : 1) |
| Polarization |
Dual Slant ±45° |
| 3 dB Beam-Width, H-Plane, typ. |
120° |
| 3 dB Beam-Width, E-Plane, typ. |
70° |
| Input power, max. |
20 watts |
| Input Impedance |
50 Ohm |
Table 2. Mechanical specifications
| Item |
Descriptions |
| Dimensions (W x L x H) |
200 x 200 x 33 mm (7.9" x 7.9" x 1.25") |
| Connector |
Two RP-SMA |
| Weight |
25.91 grams (0.057 lbs)(400 grain) |
| Back Plane |
Aluminum; protected through chemical passivation |
| Radome |
UV Protected Polycarbonate |
| Water Proofing |
IP-67 |
Table 3. Environmental specifications
| Item |
Description |
| Operating Temperature Range |
-40°C to +70°C (-40°F to +158°F) |
| Vibration |
According to IEC 60721-3-4 |
| Flammability |
UL94 |
| Humidity |
ETS 300 019-1-4, EN 302 085 (annex A.1.1) |
Radiation patterns
The following diagrams show the radiation patterns for the AI0-DD05129-RPSMA antenna.
Use this information when you pick a location for the antenna.
AI0-DD05129-RPSMA 2.5GHz
