The following table shows the Gain and Beam for the AP3000 internal antenna. Use this information when you plan your installation.
| Ports | 2.4GHz | 5GHz | 6GHz | |||
| Gain | Beam | Gain | Beam | Gain | Beam | |
| - | 4.2 | 360 | 5.07 | 360 | 5.14 | 360 |
The following diagrams illustrate the radiation patterns for the AP3000 2GHz internal antenna.
The following diagrams illustrate the radiation patterns for the AP3000 5GHz internal antenna.
The following diagrams illustrate the radiation patterns for the AP3000 6GHz internal antenna.
The following diagrams illustrate the radiation patterns for the AP3000 Bluetooth Low Energy(BLE)® internal antenna.
