An adjustable articulating mounting bracket is included with the antenna.
| Item | Description |
| Maximum power | 25 watts |
| Polarization | Dual-linear |
| Nominal impedance | 50 Ω |
| Voltage Standing Wave Radio (VSWR) | 1.0 typical 2.0 maximum |
| Front to back ratio | > 20dB |
| Radome material | UL 94-HB plastic |
| Cable | Four, 58 in. ±2 RG-58PLW, plenum |
| Mounting method | Adjustable mounting bracket for wall or pipe mounting |
| Part number | Frequency | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| WS-AI-5Q05025 (30706) | 5.1 GHz – 5.9 GHz | 3.5 dBi | 4.5 dBi | 30° | 40° | RP-SMA plug |
| Dimension | Weight | Temperature |
| 181 mm × 249 mm × 129 mm | 3.00 lbs. (1.36 kg) | −30°C to +80°C (−22°F to +176°F) |
