| Item | Description |
| Maximum power | 5 watts |
| Polarization | Linear and vertical |
| Nominal impedance | 50 Ω |
| VSWR | 2∶1 |
| Radome material | UV protected plastic |
| Cable | Four, 36 in. RG–58/U plenum-rated |
| Mounting method | Wall or mast mount |
| Part number | Frequency range | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| 30724 | 2.4 GHz – 2.5 GHz | 4.25 dBi | 5.50 dBi | Omnidirectional | 60° | N-plug |
| 5.1 GHz – 5.9 GHz | 5.00 dBi | 6.00 dBi | 33° |
| Wind rating | Dimensions | Weight | Temperature range |
| 125 mph | 218.44 mm × 160.02 mm | 3.20 lbs (1.45 kg) | Storage temperature: −40°C to +85°C (−40°F to +185°F) |
