| Item | Description |
| Maximum power | 25 watts |
| Polarization | Dual linear |
| Nominal impedance | 50 Ω |
| VSWR | <2.25∶1 |
| Front-to-back ratio | >21 dB at 2.4 GHz >14 dB at 5 GHz |
| Front-to-side ratio | 15 dB at 2.4 GHz 14 dB at 5 GHz |
| Radome material | White, UL 94-HB plastic |
| Cable | Eight 58 in. ±2 RG-58PLW plenum |
| Mounting method | Wall or pipe mount |
| Part number | Frequency range | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| 30707 | 2.4 GHz – 2.5 GHz | 10.0 dBi | 10.5 dBi | 51° | 44° | RP-SMA plug |
| 5.1 GHz – 5.9 GHz | 6.0 dBi | 7.5 dBi | 53° | 43° |
| Dimensions | Weight | Temperature range |
| 305.0 mm × 305.0 mm × 110.5 mm | 5.00 lbs (2.30 kg) | Storage temperature: −30°C to +80°C (−22°F to +176°F) |
