| Parameter | Performance |
| Maximum power | 10 watts |
| Polarization | Vertical |
| Nominal impedance | 50 Ω |
| VSWR |
| Radome material | Polycarbonate (PC) |
| Mounting method | Direct mount Pole mount using pole mount kit |
| Part number | Frequency range | Typical gain | Peak gain | Azimuth bandwidth | Elevation beamwidth | Connector |
| ML-2452-HPAG5A8-01 | 2.4 GHz – 2.5 GHz | 4.0 dBi | 4.7 dBi | 360° | 28° | Standard N-plug |
| 4.9 GHz – 5.1 GHz | 6.9 dBi | 7.1 dBi | 360° | 17° | ||
| 5.1 GHz – 5.9 GHz | 7.5 dBi | 8.0 dBi | 360° | 15° |
| Wind rating | Dimension | Weight | Temperature |
| 134 mph | 280.2 × 24.8 mm | 0.33 lb (0.15 kg) | Storage temperature: −40°C to +85°C (−40°F to +185°F) |
| Operating temperature: −30°C to +70°C (−22°F to +158°F) |
