| Parameter | Performance |
| Maximum power | 5 watts |
| Polarization | Linear, vertical |
| Nominal impedance | 50 Ω |
| VSWR | 2:1 |
| Radome material | UV protected plastic |
| Cable | Four, 36-inches RG-58/U plenum-rated cables |
| Mounting method | Wall or mast mount |
| Part number | Frequency range | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| AI-DQ04360S | 2.4–2.5 GHz | 4.25 dBi | 5.5 dBi | Omni-directional | 60° | RP-SMA plug |
| 5.1–5.9 GHz | 5 dBi | 6 dBi | 33° |
| Wind rating | Dimensions | Weight | Temperature range |
| 125 mph | 218 mm × 160 mm | 3.20 lb (1.45 kg) | Operating and Storage temperature: −40°C to +85°C (−40°F to +185°F) |
