| Item | Description |
| Maximum power | 20 watts |
| Nominal impedance | 50 Ω |
| VSWR | 1.5 typical 2.0 maximum |
| Polarization | Dual-slant linear ±45° |
| Mounting method | Wall mount or pipe mount |
| Frequency | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector type |
| 5.15 GHz – 5.85 GHz | 3 dBi | 4 dBi | 50° | 33° | Standard N-type plug |
| Part number | Dimension | Weight | Temperature |
| WS-AO-5Q04060N (30712) | 200 mm × 200 mm × 34 mm | 1.00 lb (0.45 kg) | −40°C to +70°C (−40°F to +158°F) |
