| Parameter | Performance |
| Maximum power | 20 watts |
| Polarization | Linear, vertical |
| VSWR | 2 |
| Radome material | UV stable plastic |
| Cable | 32-inches RG316 plenum-rated transparent cable |
| Mounting method | Wall mount |
| Part number | Description | 2.4 GHz gain (typical) | 2.4 GHz gain (peak) | 5 GHz gain (typical) | 5 GHz gain (peak) | Frequency range | Azimuth beamwidth | Elevation beamwidth | Connector |
| ML-2452-SEC6M4-036 | Four port sector | 6.3 | 7.0 | 6.1 | 7.3 | 2.4 GHz – 2.5 GHz | 100° | 90° | RP-SMA plug |
| 5.1 GHz – 5.9 GHz | 80° | 65° |
| Weight | Temperature range |
| 1.00 lb (0.45 kg) | Storage and operating temperature: −40°C to +70°C (−40°F to +158°F) |
