The AI-DS0305360-RPSMA antenna is a dipole antenna that provides coverage of 2.4 to 2.5 GHz and 5.1 to 5.85 GHz in a single antenna.
Use the information in the following sections when you plan your antenna installation.
The following tables show the technical and physical specifications of the AI-DS0305360-RPSMA antenna.
| Item | Description |
Antenna type |
Dipole array |
Frequency |
2400 ~ 2500 MHz 5150 ~ 5850MHz |
Impedance |
50 Ohm Nominal |
VSWR |
< 2dB |
Gain |
2.4G ~ 2.5G @ 3dBi ±0.5dBi 5.15G ~ 5.85G @ 5dBi ±0.5dBi |
Efficiency |
2.4G ~ 2.5G @ 55~60 per cent 5.15G ~ 5.85G @ 60~70 per cent |
Polarization |
Linear |
| Frequency (MHz) | Peak Gain (dBi) | Efficiency (dB) | Efficiency (percentage) |
| 2400 | 3.08 | -2.20 | 60.28 |
| 2450 | 3.17 | -2.27 | 59.33 |
| 2500 | 3.23 | -2.35 | 58.15 |
| 5150 | 5.11 | -190 | 64.63 |
| 5250 | 4.67 | -1.85 | 65.37 |
| 5350 | 5.02 | -1.63 | 67.75 |
| 5470 | 4.85 | -1.95 | 63.79 |
| 5725 | 5.15 | -2.04 | 62.55 |
| 5850 | 5.22 | -2.17 | 60.64 |
Operating temperature |
-40 ~ +80 °C |
Storage temperature |
-45 ~ +85 °C |
Connector |
SMA plug connector |
| Radome material | UV protected plastic |
The following diagrams show the radiation patterns for the AI-DS0305360-RPSMA antenna. Use this information when you pick a location for the antenna.
