AI-PD04360S is a 5-port down-tilt panel Omni antenna with RP-SMA connector. It is designed for ceiling heights between 8 feet to 25 feet.
| Parameter | Performance |
| Maximum power | 5 watt |
| Polarization | Linear, vertical and horizontal |
| Nominal impedance | 50 Ω |
| VSWR | 2:1 |
| Radome material | PC-ABS |
| Cable | RG316 |
| Mounting method | Ceiling |
Part number |
Freq. range |
Typical gain | Peak gain |
Azimuth beamwidth |
Elev. beamwidth |
Connector |
| AI-DP04360S | 2.4 GHz- 2.5GHz | 2 dBi | 3.7 dBi | 360° | 60° | RP-SMA plug |
| 5.150 GHz- 5.850 GHz | 4 dBi | 4.2 dBi | 360° | 60° |
| Dimensions | Weight | Temperature range |
| 220.0 × 69.9 mm | 1.32 lbs (0.6 kg) |
Storage temperature: −40°C to 70°C (−40°F to +158°F) Operating temperature: −40°C to 70°C (−40°F to +158°F) |
