| Item | Description |
| Polarization | Dipole |
| VSWR | <2.0 |
| Nominal impedance | 50 Ω |
| Radome material | PC1110U plastic |
| Cable | RG-178 |
| Mounting method | Direct attach |
| Part number | Frequency range | Typical gain | Peak gain | Azimuth bandwidth | Elevation bandwidth | Connector |
| ML-2452-HPA6-01 | 2.4 GHz – 2.5 GHz | 1.1 dBi | 5.3 dBi | 360° | 100° | N-type plug |
| 5.1 GHz – 5.9 GHz | 2.5 dBi | 6.1 dBi | 360° | 30° |
| Dimensions | Weight | Temperature range |
| 318.20 mm × 22 mm | 0.235 lbs (0.107 kg) | Storage and operational temperature: −40°C to +85°C (−40°F to +185°F) |
