ML-2452-HPA5-036 Antenna Ceiling Install
Tip
The best practice is to mount the antenna on a ceiling or roof-level near the center of the coverage area.The following hardware is required for installing the antenna on
a ceiling:
- Ceiling mount adapter plate
- Two, #6 internal tooth lock washers
- Two, #6–32 × ¼ in. SS screws
- ¼ in. internal tooth lock washer
- Ceiling hanger (grid) bracket
- 5/16 – 18 SS hex nut
