Vertical Surface Installation
- One mount base
- One wall bracket
- One screen mesh washer
- One spherical washer
- One ¼ – 20 wing screw
- Two #10 × ¾ in. screws
- One mount interface bracket
- Two #10 × ½ in. screws
Attach the mount interface
bracket to the antenna using the jam nut.
Antenna mount interface bracket attached to the antenna
Callout Description A Antenna B Mount interface bracket alignment hole C Jam nut - Place the screen mesh washer between the mount interface bracket and the mount base.
Attach the mount base to the
mount interface bracket using the spherical washer and the ¼ – 20 wing
screw.
Callout Description A Spherical washer B Mount base C Screen mesh washer - Use the wall bracket holes as a template, mark and drill two attachment holes on a flat vertical surface.
Attach the wall bracket to a
wall using two #10 × ¾ in. screws.
Callout Description A Flat vertical surface B Wall bracket -
Slide the mount base on the
wall bracket, and secure it in place with two #10 × ½ in. screws.
Callout Description A Wall bracket B Mount base -
Adjust the antenna azimuth
and elevation.
To adjust the azimuth and elevation, loosen the jam nut on the mount base.
Azimuth can be adjusted ±78°.
Azimuth adjustment
Elevation cab be adjusted ±15° and −35°.
Elevation adjustment
