You can connect the antenna directly onto the access point. The AH-ACC-ANT-AX-KT
antenna is compatible with AP305C/CX and AP510C/CX access points. Attach the antenna after you install the access point.
Line up the antenna connector
and the antenna port on the access point.
Refer to the External Antenna Connectors topic for information on antenna connector on various access
points.
Twist the antenna connector clockwise to attach it to the antenna port.
