The ML-2452-SEC6M4-036 antenna is mounted to a wall.
ML-2452-SEC6M4-036 antenna box contents:
- A wall mount kit, that includes:
- Four plastic wall insert plugs
- Four self-tapping screws
- Four flat washers
- One ML-2452-SEC6M4-036 antenna
- One wall mount instructions sheet
- One Waste Electrical and Electronic Equipment (WEEE) document
- One China RoHS sheet
Using the ML-2452-SEC6M4-036
antenna holes as a template, mark and drill four, 5 × 35 mm holes on a
wall.
Antenna mounting
holes
| Callout |
Description |
| A |
Antenna hole templates for wall mount
installation |
Insert four plastic wall insert plugs into the mounting holes.
Place a flat washer on every antenna mounting hole template, and insert the
self tapping screw through the flat washer.
| Callout |
Description |
| A |
Self tapping screw |
| B |
Flat washer |
Antenna cables are not shown in the antenna images.
Insert the self tapping screws into the plastic wall insert plugs, and tighten
the screws.
Self tapping screws inserted into the plastic wall insert
plugs
