AP5020 Internal Antenna
Specifications and Radiation Patterns
Specifications
The following table shows the Gain and Beam for the
AP5020
internal antenna. Use this information when you plan your installation.
Table 1. Ports, Gains, and Beam
| Radio |
2.4 GHz |
5 GHz |
6 GHz |
4dBi |
360 |
6dBi |
360 |
6dBi |
360 |
2.4 GHz Radiation Patterns
The following diagrams illustrate the radiation patterns for the
AP5020 2GHz internal
antenna.
AP5020 2GHz Vertical Radiation Pattern
AP5020 2GHz Horizontal Radiation Pattern
5 GHz Radiation Patterns
The following diagrams illustrate the radiation patterns for the AP5020 5 GHz internal antenna.
AP5020 5 GHz Vertical Radiation Pattern
AP5020 5 GHz Horizontal Radiation Pattern
6 GHz Radiation Patterns
The following diagrams illustrate the radiation patterns for the AP5020 6 GHz internal antenna.
AP5020 6 GHz Vertical Radiation Pattern
AP5020 6 GHz Horizontal Radiation Pattern
