Indoor cable details | Reference |
10.00 ft (3.05 m) PFP240 cable (WS-CAB240- P10RP) | WS-CAB240-P10RP and WS-CAB240-P25RP cable specifications |
25.00 ft (7.62 m) PFP240 cable (WS-CAB240- P25RP) |
Specification | Value |
Mechanical | |
Length | WS-CAB240-P10RP: 10.00 ft (3.05 m) WS-CAB240-P25RP: 25.00 ft (7.62 m) |
Weight | 0.002 lb/ft (0.03 kg/m) |
Bend radius | 0.5 in (12.7 mm) |
Tensile strength | 40.0 lb (18.2 kg) |
Environmental | |
Temperature range | Operating: -40°C to +85°C (-40°F to +185°F) Storage: -70°C to +85°C (-94°F to +185°F) |
Electrical | |
Cutoff frequency | 39 GHz |
Velocity propagation | 83% |
Shielding effectiveness | Greater than 90 dBi |
DC resistance | Inner Conductor: 5.36 ohms/1000 ft (17.60 ohms/km) Outer Conductor: 4.9 ohms/1000 ft (16.1 ohms/km) |
Peak power | 2.5 kW |
Connector type | Outdoor antennas support optional cables with standard polarity type-N plug and type-N jack. Indoor antennas support optional cables with standard RP-SMA type plug connectors. |
Cable loss | 2.4 GHz: 3.3 dB 5.3 GHz: 5.0 dB 5.8 GHz: 5.3 dB |
Outdoor cable details | Reference |
20.00 ft (6.10 m) PFP240 cable (WS-CABL200C20N) | WS-CABL200C20N cable specifications |
6.00 ft (1.83 m) PFP400 cable (WS-CABL400C06N) | WS-CAB-L400C06N, WS-CAB-L400C20N, WS-CAB-L400C50N, and WS-CAB-L400C75N cable specifications |
20.00 ft (6.10 m) PFP400 cable (WS-CABL400C20N) | WS-CAB-L400C06N, WS-CAB-L400C20N, WS-CAB-L400C50N, and WS-CAB-L400C75N cable specifications |
50.00 ft (15.24 m) PFP400 cable (WS-CABL400C50N) | WS-CAB-L400C06N, WS-CAB-L400C20N, WS-CAB-L400C50N, and WS-CAB-L400C75N cable specifications |
75.00 ft (22.00 m) PFP400 cable (WS-CABL400C75N) | WS-CAB-L400C06N, WS-CAB-L400C20N, WS-CAB-L400C50N, and WS-CAB-L400C75N cable specifications |
25.00 ft (7.60 m) PFP600 cable (WS-CABL600C25N) | WS-CAB-L600C25N and WS-CAB-L600C50N cable specifications |
50.00 ft (15.24 m) PFP600 cable (WS-CABL600C50N) | WS-CAB-L600C25N and WS-CAB-L600C50N cable specifications |
Mechanical | |
Length | 20.00 ft (6.10 meters) |
Environmental | |
Electrical | |
DC resistance | Inner Conductor: 5.36 ohms/1000ft (17.6 ohms/km) Outer Conductor: 4.9 ohms/1000ft (16.1 ohms/km) |
Mechanical | |
Length |
WS-CAB-L400C06N: 6.00 ft (1.83 m) WS-CAB-L400C20N: 20.00 ft (6.10 m) WS-CAB-L400C50N: 50.00 ft (15.24 m) WS-CAB-L400C75N: 75.00 ft (22.00 m) |
Weight | 0.068 lb/ft (0.10 kg/m) |
Bend radius | 1.00 in (25.40 mm) |
Tensile strength | 160.0 lb (72.6 kg) |
Environmental | |
Electrical | |
Cutoff frequency | 16.2 GHz |
Velocity propagation | 85% |
DC resistance | Inner Conductor: 1.39 ohms/1000 ft (4.6 ohms/km) Outer Conductor: 1.65 ohms/1000 ft (5.4 ohms/km) |
Peak power | 16 kW |
Connector type |
Outdoor antennas support optional cables with standard polarity type-N plug and type-N jack. |
Cable loss | 50.00 ft:
75.00 ft:
Mechanical | |
Length |
WS-CAB-L600C25N: 25.00 ft (7.60 m) WS-CAB-L600C50N: 50.00 ft (15.24 m) |
Weight | 0.131 lb/ft (0.200 kg/m) |
Bend radius | 1.50 in (38.10 mm) |
Tensile strength | 350.0 lb (158.9 kg) |
Environmental | |
Electrical | |
Cutoff frequency | 10.3 GHz |
Velocity propagation | 87% |
DC resistance | Inner Conductor: 0.53 ohms/1000 ft (1.70 ohms/km) Outer Conductor: 1.20 ohms/1000 ft (3.90 ohms/km) |
Peak power | 40 kW |
Connector type |
Cable loss | 25.00 ft:
50.00 ft:
