mint
Displays MiNT protocol related
statistics and configuration
- Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
show mint [config|dis|id|info|known-adopters|links|lsp|lsp-db|mlcp|neighbors|route|
stats|tunnel-controller|tunneled-vlans]
show mint [config|id|info|known-adopters|route|stats|tunneled-vlans]
{on <DEVICE-NAME>}
show mint [dis|links|neighbors|tunnel-controller] {details} {(on <DEVICE-NAME>)}
show mint lsp
show mint lsp-db {details <MINT-ADDRESS>} {(on <DEVICE-NAME>)}
show mint mlcp {history} {(on <DEVICE-NAME>)}
Parameters
show mint [config|id|info|known-adopters|route|stats|tunneled-vlans] {on <DEVICE-NAME>}
| mint |
Displays MiNT protocol information based on the parameters
passed |
| config |
Displays MiNT configuration |
| id |
Displays local MiNT ID |
| info |
Displays MiNT status |
| known-adopters |
Displays known, possible, or reachable adopters |
| route |
Displays MiNT route table details |
| stats |
Displays MiNT related statistics |
| tunneled-vlans |
Displays MiNT tunneled VLAN details |
| on <DEVICE-NAME> |
The following keywords are common to all of the above parameters:
- on <DEVICE-NAME>
– Optional. Displays MiNT protocol details on a specified device
- <DEVICE-NAME> – Specify the name of the AP, wireless
controller, or service platform.
| mint |
passed |
| dis |
Displays MiNT network Designated Intermediate Systems (DISes) and
Ethernet Virtualization Interconnects (EVISes) |
| links |
Displays MiNT networking link details |
| neighbors |
Displays adjacent MiNT peer details |
| tunnel-controller |
Displays details of MiNT VLAN network tunnel wireless controllers for
extended VLAN load balancing |
| details {(on <DEVICE-NAME>)} |
The following keywords are common to the ‘dis', ‘links', ‘neighbors',
and ‘tunnel-controller' parameters:
- details – Optional.
Displays detailed MiNT information
- on
<DEVICE-NAME> – Optional. This is a recursive parameter,
which displays MiNT information on a specified device
wireless controller, or service platform.
show mint lsp
| mint |
passed |
| lsp |
Displays this router's MiNT Label Switched Paths (LSPs) |
| mint |
passed |
| lsp-db |
Displays MiNT LSP database entries |
| details <MINT_ADDRESS> |
Optional. Displays detailed MiNT LSP database entries
- <MINT_ADDRESS> –
Specify the MiNT address in the AA.BB.CC.DD format.
| on <DEVICE-NAME> |
The following keyword is recursive and common to the ‘details'
parameter:
- on <DEVICE-NAME>
– Optional. Displays MiNT LSP database entries on a specified
device
| mint |
Displays MiNT protocol information based on the parameters passed This
command displays the ‘hello-interval‘ and ‘hold-time‘ default values for
both IP and VLAN links.
| mlcp |
Displays MiNT Link Creation Protocol (MLCP) status |
| history |
Optional. Displays MLCP client history |
| on <DEVICE-NAME> |
The following keyword is recursive and common to the ‘history'
parameter:
- on <DEVICE-NAME>
– Optional. Displays MLCP client history on a specified device
NOC-NX9500#show mint stats
2 Level-1 neighbors
Level-1 LSP DB size 5 LSPs (1 KB)
Last Level-1 SPFs took 0.000s
Level-1 SPF (re)calculated 6 times.
5 Level-1 paths.
0 Level-2 neighbors
Level-2 LSP DB size 0 LSPs (0 KB)
Last Level-2 SPFs took 0.000s
Level-2 SPF (re)calculated 0 times.
0 Level-2 paths.
NOC-NX9500#
NOC-NX9500#show mint lsp
id 19.6C.88.09, level 1, 2 adjacencies, 0 extended-vlans
seqnum 1519955, expires in 22 minutes, republish in 774 seconds
90 bytes, can-adopt: True, adopted-by: 00.00.00.00, dis-priority 5, Level-2-gateway: False
hostname "NOC-NX9500"
rf-domain "default", priority vector: 0xe0dc0000
adjacent to 70.38.06.49, cost 100
adjacent to 19.6D.B5.D4, cost 100
NOC-NX9500#
NOC-NX9500#show mint lsp-db
5 LSPs in LSP-db of 19.6C.88.09:
LSP 19.6C.88.09 at level 1, hostname "NOC-NX9500", 2 adjacencies, seqnum 1519955
LSP 19.6D.B5.D4 at level 1, hostname "SITE2-VLAN192", 2 adjacencies, seqnum 1972642
LSP 19.74.B4.5C at level 1, hostname "ap8132-74B45C", 1 adjacencies, seqnum 1742227
LSP 4D.83.30.A4 at level 1, hostname "ap7522-8330A4", 1 adjacencies, seqnum 519924
LSP 70.38.06.49 at level 1, hostname "SITE1-VLAN20", 2 adjacencies, seqnum 1391030
NOC-NX9500#
NOC-NX9500#show mint route
Destination : Next-Hop(s)
19.6D.B5.D4 : 19.6D.B5.D4 via ip-192.168.13.2:24576
19.74.B4.5C : 19.6D.B5.D4 via ip-192.168.13.2:24576
19.6C.88.09 : 19.6C.88.09 via self
70.38.06.49 : 70.38.06.49 via ip-20.168.10.2:24576
4D.83.30.A4 : 70.38.06.49 via ip-20.168.10.2:24576
NOC-NX9500#
NOC-NX9500#show mint config
Base priority 5
DIS priority 5
Control priority 220
UDP/IP Mint encapsulation port 24576
Global Mint MTU 1500
NOC-NX9500#
NOC-NX9500#show mint mlcp
MLCP VLAN state: MLCP_INIT
MLCP VLAN Hello Interval: 4s(default), Adjacency hold time: 13s(default)
Potential VLAN links: None
All VLANs were scanned 1 times
MLCP IP: ENABLED
MLCP IPv6: ENABLED
MLCP IP/IPv6 state: MLCP_INIT
MLCP IP Hello Interval: 15s(default), Adjacency hold time: 46s(default)
Potential L3 Links:
None
NOC-NX9500#
