Enables forwarding of WNMP (Wireless Network Management Protocol) packets across L2 tunnels. Under normal circumstances, if L2 tunnel broadcast optimization is enabled. WNMP packets are not forwarded across the L2 tunnels. Use this option to enable the forwarding of only WNMP packets.
l2-tunnel-forward-additional-packet-types wnmp
None
nx9500-6C8809(config-profile testNX9000-bridge-vlan-1)#l2-tunnel-forward-additional-packet-types wnmp nx9500-6C8809(config-profile testNX9000-bridge-vlan-1)#show context bridge vlan 1 l2-tunnel-broadcast-optimization l2-tunnel-forward-additional-packet-types wnmp ip igmp snooping ip igmp snooping querier ipv6 mld snooping ipv6 mld snooping querier nx9500-6C8809(config-profile testNX9000-bridge-vlan-1)#
| no | Disables WNMP packet forwarding across L2 tunnel |
