Configures WLAN‘s RF Domain level overrides
override-wlan <WLAN> [shutdown|ssid <SSID>|vlan-pool <1-4094> {limit <0-8192>}|
wpa-wpa2-psk <WORD>]
| <WLAN> | Specify the WLAN name. Configure the following WLAN parameters: SSID, VLAN pool, and WPA-WPA2 key. |
| shutdown | Shuts down the WLAN‘s (identified by the <WLAN> keyword) operations on all mapped radios |
| SSID <SSID> | Configures the WLAN‘s Service Set Identifier (SSID)
| vlan-pool <1-4094> {limit <0-8192>} | Configures a pool of VLANs for the selected WLAN
| wpa-wpa2-psk <WORD> | Configures the WLAN WPA-WPA2 key or passphrase for the selected WLAN
override-wlan <WLAN> wep128 [key <1-4> hex [0<WORD>|2 <WORD>]|transmit-key <1-4>]
| <WLAN> | Specify the WLAN name. |
| wep128 [key <1-4> hex [0<WORD>| 2 <WORD>]| transmit-key <1-4> | Configures the WEP128 key for this WLAN,
and also enables key transmission Wired Equivalent Privacy (WEP) is a security protocol specified in the IEEE Wireless Fidelity (Wi -Fi) standard. WEP 128 uses a 104 bit key, which is concatenated with a 24-bit initialization vector (IV) to form the RC4 traffic key. This results in a level of security and privacy comparable to that of a wired LAN.
Wireless devices and their connected clients use the algorithm to convert an ASCII string to the same hexadecimal number. Clients without the required adapters need to use WEP keys manually configured as hexadecimal numbers. |
nx9500-6C8809(config-device-94-9B-2C-13-3E-1C)#override-wlan test vlan-pool 8 nx9500-6C8809(config-device-94-9B-2C-13-3E-1C)#show context ap505 94-9B-2C-13-3E-1C use profile default-ap505 use rf-domain default hostname TechPubAP505 floor 5thfloor layout-coordinates 1.0 2.0 license AP aplicenseley@1234 aplicensekey@123 location SanJose no contact country-code us channel-list 2.4GHz 1,2 override-wlan test vlan-pool 8 mac-name 94-9B-2C-13-3E-1C 5.8TestAP neighbor-info-interval 50 nx9500-6C8809(config-device-94-9B-2C-13-3E-1C)#
| no | Removes RF Domain level WLAN overrides |
