default-next-hop [<IP>|<ROUTER-IF-NAME>|pppoe1|serial <SLOT-ID> <PORT-ID> <CHANNEL-GROUP-ID>|vlan <1-4094>|wwan1]
| default-next--hop | Sets the next hop router to which packets are sent in case the next hop is not the adjacent router |
| <IP> | Specifies next hop router‘s IP address |
| <ROUTER-IF-NAME> | Specifies the outgoing interface name (router interface name) |
| pppoe1 | Specifies the PPPoE interface |
| serial <SLOT-ID> <PORT-ID> <CHANNEL-GROUP-ID> | Specifies the serial interface‘s slot, port, and channel group IDs |
| vlan <1-4094> | Specifies a VLAN interface ID
| wwan1 | Specifies the WAN interface |
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#default-next-hop wwan1
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#show context route-map 1 default-next-hop wwan1 nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#
| no (route-map-config-mode-command) | Removes default next hop router settings |
