When enabled, if the RADIUS server as part of the authentication process returns a client‘s VLAN-ID in a RADIUS access-accept packet, then all client traffic is forwarded on the post authentication VLAN. If disabled, the RADIUS server‘s VLAN assignment is ignored and the VLAN configuration defined within the WLAN configuration is used instead. This feature is disabled by default.
radius-vlan-assignment
None
nx9500-229D58(config-captive-portal-test)#radius-vlan-assignment
nx9500-229D58(config-captive-portal-test)#show context captive-portal test post-authentication-vlan 1 radius-vlan-assignment nx9500-229D58(config-captive-portal-test)#
| no | Disables assignment of a RADIUS VLAN for this captive portal |
