telnet
Enables Telnet. Telnet provides a
command line interface to a remote host over TCP. Telnet provides no encryption, but it
does provide a measure of authentication. Telnet access is disabled by default.By
default Telnet, when enabled, uses Transmission Control Protocol (TCP) port
23. Use this command to change the TCP port.
- Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
telnet {port <1-65535>}
Parameters
| telnet |
Enables Telnet |
| port <1-65535> |
Optional. Configures the Telnet port. This is the port used for Telnet
connections.
- <1-65535> – Sets
a value from 1 - 165535. The default port is 23.
nx9500-6C8809(config-management-policy-test)#telnet port 200
nx9500-6C8809(config-management-policy-test)#show context
management-policy test
telnet port 200
no http server
https server
ftp username superuser password 1 626b4033263d6d2ae4e79c48cdfcccb60fd4c77a8da9e365060597a6d6570ec2 rootdir dir
ssh port 162
snmp-server community snmp1 ro
snmp-server user snmpmanager v3 encrypted des auth md5 0 test123
snmp-server host 172.16.10.23 v3 162
aaa-login radius external
aaa-login radius policy test
idle-session-timeout 0
restrict-access host 172.16.10.2 log all
