wireless-client
Supported in the
following platforms:
- Access Points — AP3000/X, AP5010, AP310i/e, AP410i/e,
AP460i/e, AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612,
AP7632, AP7662, AP8432, AP8533
wireless-client tx-power [<0-20>|mode]
wireless-client tx-power mode [802.11d {wing-ie}|wing-ie {802.11d}]
Parameters
wireless-client tx-power <0-20>
| wireless-client |
Configures
wireless client parameters |
| tx-power
<0-20> |
Configures the
transmit power indicated to wireless clients. If using a dual or three radio
model access point, each radio should be configured with a unique transmit
power in respect to its intended client support function. A setting of 0
defines the radio as using Smart RF to determine its output power. 20 dBm is
the default value.
- <0-20> – Specify
transmit power from 0 - 20 dBm.
| wireless-client |
Configures
| tx-power
[802.11d|wing-ie] |
Configures the
- 802.11d – Advertises in
the IEEE 802.11d country information element
- wing-ie – Optional.
Advertises in the WiNG information element (173)
- wing-ie – Advertises in
the WiNG information element (173). This is the default setting.
- 802.11d – Optional.
Advertises in the IEEE 802.11d country information element
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#wireless-client tx-power 20
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
interface radio1
rf-mode sensor
placement outdoor
mesh client
rts-threshold 100
off-channel-scan channel-list 2.4GHz 1
guard-interval long
aggregation ampdu tx-only
--More--
