MeshConnex (MCX) is a mesh networking technology that is comparable to the 802.11s mesh networking specification. MeshConnex meshing uses a hybrid proactive/on-demand path selection protocol, similar to Ad-hoc On Demand Distance Vector (AODV) routing protocols. This allows it to form efficient paths using multiple attachment points to a distribution WAN, or form purely ad-hoc peer-to-peer mesh networks in the absence of a WAN. Each device in the MeshConnex mesh proactively manages its own path to the distribution WAN, but can also form peer-to-peer paths on demand to improve forwarding efficiency.
MeshConnex is not compatible with MiNT Based meshing, though the two technologies can be enabled simultaneously in certain circumstances.
MeshConnex is designed for large-scale, high-mobility outdoor mesh deployments. MeshConnex continually gathers data from beacons and transmission attempts to estimate the efficiency and throughput of each MP-to-MP link. MeshConnex uses this data to dynamically form and continually maintain paths for forwarding network frames.
In MeshConnex systems, a meshpoint is a virtual mesh networking instance on a device, similar to a WLAN AP. On each device, up to 4 MPs can be created and 2 can be created per radio. MPs can be configured to use one or both radios in the device. If the MP is configured to use both radios, the path selection protocols continuously selects the best radio to reach each destination. Each MP participates in a single Mesh Network, defined by the MeshID. The MeshID is typically a descriptive network name, similar to the SSID of a WLAN. All MPs configured to use the same MeshID attempt to form a mesh and interoperate. The MeshID allows overlapping mesh networks to discriminate and disregard MPs belonging to different networks.
Use the (config) instance to configure meshpoint related configuration commands. To navigate to the meshpoint instance, use the following command:
<DEVICE>(config)#meshpoint <MESHPOINT-NAME>
nx9500-6C8809(config)#meshpoint test nx9500-6C8809(config-meshpoint-test)#? Mesh Point Mode commands: allowed-vlans Set the allowed VLANs beacon-format The beacon format of this meshpoint control-vlan VLAN for meshpoint control traffic data-rates Specify the 802.11 rates to be supported on this meshpoint description Configure a description of the usage of this meshpoint force Force suboptimal paths meshid Configure the Service Set Identifier for this meshpoint neighbor Configure neighbor specific parameters no Negate a command or set its defaults root Set this meshpoint as root security-mode The security mode of this meshpoint shutdown Shutdown this meshpoint use Set setting to use wpa2 Modify ccmp wpa2 related parameters clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-meshpoint-test)#
The following table summarizes meshpoint configuration commands.
| Command | Description |
| allowed-vlans (meshpoint-config) | Configures VLANs allowed on the meshpoint |
| beacon-format (meshpoint-config) | Configures the beacon format for the meshpoint AP |
| control-vlan (meshpoint-config) | Configures the VLAN where meshpoint control traffic traverses |
| data-rates (meshpoint-config) | Configures the data rates supported per frequency band |
| description (meshpoint-config) | Configures a human friendly description for this meshpoint |
| force (meshpoint-config) | Forces formation of sub-optimal paths through the meshpoint‘s root node |
| meshid (meshpoint-config) | Configures a unique ID for this meshpoint |
| neighbor (meshpoint-config) | Configures the neighbor inactivity time out for this meshpoint |
| root (meshpoint-config) | Configures a meshpoint as the root meshpoint |
| security-mode (meshpoint-config) | Configures the security mode on the meshpoint. |
| service (meshpoint-config) | Allows only 802.11n capable neighbors to create a mesh connection |
| shutdown (meshpoint-config) | Shuts down the meshpoint |
| use (meshpoint-config) | Associates a QoS policy with this meshpoint |
| wpa2 (meshpoint-config) | Configures WPA2 encryption settings |
| no (meshpoint-config) | Removes or reverts this Meshpoint settings |
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands.
The input parameter <HOSTNAME>, wherever used in syntax across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.
