router-preference
Configures the router preference field
value advertised in RAs. The options are high, medium, and low. This value is used to
prioritize and select the default router when multiple routers are discovered.
- Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
router-preference [high|medium|low]
Parameters
| router-preference [high|medium|low] |
Sets this router‘s preference over other routers, in the link, to be the
default router. The options are high, low, and
medium. The default value is medium. The following points
should be taken into consideration when configuring router preference:
- For a router to be selected
as a default router, the router‘s lifetime should not be equal to “0”.
- To enable default router
selection, using router information contained in RAs, configure default router
selection on that interface.
nx9500-6C8809(config-ipv6-radv-policy-test)#router-preference high
nx9500-6C8809-6C8809(config-ipv6-radv-policy-test)#show context
ipv6-router-advertisement-policy test
ra suppress
ra interval 200
managed-config-flag
nd-reachable-time global
router-lifetime 2000
advertise mtu
advertise hop-limit
check-ra-consistency
dns-server 2002::2 lifetime 3000
domain-name TechPubs lifetime infinite
