report-royalty-application
Enables detection of captive portal
client‘s usage of a selected (preferred) loyalty application
- Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
report-loyalty-application {custom-app <APPLICATION-NAME>}
Parameters
<APPLICATION-NAME>} |
Reports a captive portal client‘s loyalty application
presence and stores this information in the captive portal‘s user database. The
client‘s loyalty application detection occurs on the access point to which the
client is associated. Retail administrators can use this information to assess
whether patrons‘ loyalty application usage is as per expectation within specific
retail environments. This option is disabled by default.
- custom-app <APPLICATION-NAME> – Optional. Uses a custom application
definition as match criteria.
- <APPLICATION-NAME> – Specify the custom
application name (should be existing and configured).
Ensure that the application specified is available and
configured. If not, create an application definition.
For more information, see application.
If no custom application definition is specified, the system uses
localization to detect application presence.
nx9500-6C8809(config-captive-portal-test)#report-loyalty-application custom-app
AntiVirus
nx9500-6C8809(config-captive-portal-test)#show context include-factory | include
report-loyalty-application custom-app AntiVirus
Related Commands
| no |
Disables detection of customer-loyalty application presence |
