non-unicast
Supported in the
following platforms:
- Access Points — AP3000/X, AP5010, AP310i/e, AP410i/e,
AP460i/e, AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612,
AP7632, AP7662, AP8432, AP8533
non-unicast [forwarding|queue|tx-rate]
non-unicast forwarding [follow-dtim|power-save-aware]
non-unicast queue [<1-200>|bss]
non-unicast queue [<1-200>|bss <1-16> <1-200>]
non-unicast tx-rate [bss <1-16>|dynamic-all|dynamic-basic|highest-basic|lowest-basic]
non-unicast tx-rate bss <1-16> [dynamic-all|dynamic-basic|highest-basic|lowest-basic]
Parameters
| non-unicast
forwarding |
Enables
non-unicast frame forwarding on this radio. Once enabled, select one of the
available options to specify whether these frames should always follow DTIM,
or only follow DTIM when using power save aware mode. |
| follow-dtim |
Specifies frames
always wait for the DTIM interval to time out. The DTIM interval is
configured using the beacon command. This is the default setting. |
| power-save-aware |
Enables
immediate forwarding of frames only if all associated wireless clients are
in the power save mode |
| non-unicast
queue |
Enables
non-unicast frame forwarding on this radio. Once enabled, specify the number
of broadcast packets queued per BSS on this radio. This option is enabled by
default. This command also
enables you to override the default on a specific BSS.
| <1-200> |
Specify a number
from 1 - 200. This value applies to all BSSs. The default is 50 frames per
BSS. |
| bss <1-16>
<1-200> |
Overrides the
default on a specified BSS
- <1-16> – Select the
BSS number from 1 - 16.
- <1-200> –
Specify the number of broadcast packets queued for the selected
BSS from 1 - 200.
| non-unicast
tx-rate |
Enables
non-unicast frame forwarding on this radio. Once enabled, use one of the
available options to configure the rate at which these frames are
transmitted. |
| bss
<1-16> |
Overrides the
BSS number from 1 - 16. The transmit rate selected is applied only to
the BSS specified here. The tx-rate options are: dynamic-all,
dynamic-basic, highest-basic, lowest-basic.
| dynamic-all |
Dynamically
selects a rate from all supported rates based on current traffic
conditions |
| dynamic-basic |
Dynamically
selects a rate from all supported basic rates based on current traffic
conditions |
| highest-basic |
Uses the highest
configured basic rate. This is the default setting. |
| lowest-basic |
Uses the lowest
configured basic rate |
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#non-unicast queue bss 2 3
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#non-unicast tx-rate bss 1 dynamic-all
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
interface radio1
data-rates b-only
mesh client
guard-interval long
aggregation ampdu tx-only
aeroscout forward
ekahau forward ip 172.16.10.1 port 3
non-unicast tx-rate bss 2 highest-basic
non-unicast tx-rate bss 3 highest-basic
non-unicast tx-rate bss 4 highest-basic
non-unicast tx-rate bss 5 highest-basic
non-unicast tx-rate bss 6 highest-basic
non-unicast tx-rate bss 7 highest-basic
non-unicast tx-rate bss 8 highest-basic
non-unicast tx-rate bss 9 highest-basic
non-unicast tx-rate bss 10 highest-basic
non-unicast tx-rate bss 11 highest-basic
non-unicast tx-rate bss 12 highest-basic
non-unicast tx-rate bss 13 highest-basic
non-unicast tx-rate bss 14 highest-basic
non-unicast tx-rate bss 15 highest-basic
non-unicast tx-rate bss 16 highest-basic
non-unicast queue bss 1 50
--More--
antenna-diversity
max-clients 100
airtime-fairness prefer-ht weight 6
lock-rf-mode
extended-range 15
antenna-downtilt
