The DHCP server policy defines the parameters required to run a DHCP server on the wireless controller and assign IP addresses automatically to devices that associate. Configuring DHCP enables the reuse of a limited set of IP addresses.
To create a DHCP server policy, in the wireless controller‘s global configuration mode, execute the following command:
rfs4000-37FABE(config)#dhcp-server-policy <DHCP-SERVER-POLICY-NAME>
rfs4000(config)#dhcp-server-policy DHCP_POLICY_UseCase1 rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1)#
The following table displays how IP addresses are used.
IP Range |
Usage |
172.16.11.1 till 172.16.11.10 |
Reserved for devices that require a static IP address |
172.16.11.11 till 172.16.11.200 |
Range of IP addresses that can be assigned using the DHCP server. |
172.16.11.201 till 172.16.11.254 |
In the table, the IP address range of 172.16.11.11 to 172.16.11.200 is available using the DHCP server. To configure the DHCP server:
rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1)#dhcp-pool DHCP_POOL_USECASE1_01 rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1-pool-DHCP_POOL_USECASE1_01)#
rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1-pool-DHCP_POOL_USECASE1_01)#address range 172.16.11.11 172.16.11.200 rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1-pool-DHCP_POOL_USECASE1_01)#
rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1-pool-DHCP_POOL_USECASE1_01)#network 172.16.11.0/24 rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1-pool-DHCP_POOL_USECASE1_01)#exit rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1)#exit rfs4000(config)#commit write
rfs4000-37FABE(config)#self rfs4000-37FABE(config-device-03-14-28-57-14-28)#use dhcp-server-policy DHCP_POLICY_UseCase1 rfs4000-37FABE(config-device-03-14-28-57-14-28)#commit write rfs4000-37FABE(config-device-03-14-28-57-14-28)#exit rfs4000-37FABE(config)#
