no [accounting|attribute|authentication|health-check|mac-address-format|proxy-attribute| server-pooling-mode|use]
no accounting interim interval
no accounting server preference
no accounting server <1-6> {dscp|nai-routing|proxy-mode|retry-timeout-factor|timeout}
no accounting type
no attribute [acct-delay-time|acct-multi-session-id|chargeable-user-identity| cisco-vsa audit-session-id|framed-ip-address|framed-mtu|location-information|nas-ipv6-address| operator-name|service-type]
no authentication [eap|protocol|server]
no authentication eap wireless-client [attempts|identity-request-retry-timeout| identity-request-timeout|retry-timeout-factor|timeout]
no authentication protocol
no authentication server <1-6> {dscp|nac|nai-routing|proxy-mode|retry-timeout-factor|timeout}
no health-check interval
no mac-address-format
no proxy-attribute [nas-identifier|nas-ip-address]
no server-pooling-mode
no use nac-list
no <PARAMETERS>
| no <PARAMETERS> | Removes or reverts to default the selected AAA policy settings |
The following example shows the AAA policy ‘test‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-aaa-policy-test)#show context aaa-policy test authentication server 5 host 172.16.10.10 secret 0 test1 port 1 authentication server 5 timeout 10 attempts 3 accounting server 2 host 172.16.10.10 secret 0 test1 port 1 accounting server 2 timeout 2 attempts 2 mac-address-format quad-dot case upper attributes username-password authentication protocol chap accounting interim interval 65 accounting server preference auth-server-number health-check interval 4000 attribute framed-mtu 110 nx9500-6C8809(config-aaa-policy-test)#
nx9500-6C8809(config-aaa-policy-test)#no accounting server 2 timeout 2
nx9500-6C8809(config-aaa-policy-test)#no accounting interim interval
nx9500-6C8809(config-aaa-policy-test)#no health-check interval
nx9500-6C8809(config-aaa-policy-test)#no attribute framed-mtu
nx9500-6C8809(config-aaa-policy-test)#no authentication protocol
The following example shows the AAA policy ‘test‘ settings after the ‘no‘ commands are executed:
nx9500-6C8809(config-aaa-policy-test)#show context aaa-policy test authentication server 5 host 172.16.10.10 secret 0 test1 port 1 authentication server 5 timeout 10 attempts 3 accounting server 2 host 172.16.10.10 secret 0 test1 port 1 mac-address-format quad-dot case upper attributes username-password accounting server preference auth-server-number health-check interval 4000 nx9500-6C8809(config-aaa-policy-test)#
