port (bgp-neighbor-config)
Configures a non-standard BGP port for this BGP neighbor. By default BGP
uses port 179. Use this command to set a non standard port for this BGP neighbor.
- Service Platforms — NX9500, NX9600
Parameters
port <0-65535>
| port <0-65535> |
Specify a value from 0 - 65535. |
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#port 21
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
bgp neighbor 192.168.13.99
advertisement-interval 100
peer-group eBGPPeerGrp1
port 21
allowas-in 10
attribute-unchanged as-path
capability orf prefix-list both
default-originate
description neighbor "This neighbor is an external AS neighbor"
disable-connected-check
dont-capability-negotiate
ebgp-multihop 20
enforce-multihop
local-as 20 no-prepend
maximum-prefix 400 50 warning-only
next-hop-self
override-capability
passive
password neighbor eBGPneighbor@300
