t5 (management-policy)
Configures SNMP
server settings for T5 devices on this management policyA T5 controller
is an external device that can be adopted and managed by a WiNG
controller. When enabled as a supported external device, the T5
controller provides data to WiNG to assist in it‘s management within a
WiNG supported subnet.
This command enables SNMP to communicate
with T5 devices within the network. SNMP facilitates the exchange of
management information between the controller or service platform and
the T5 device. For more information, see snmp-server.
- Service Platforms —
NX9500, NX9600
Syntax
t5 snmp-server [community|contact|enable|host|location]
t5 snmp-server community <COMMUNITY-NAME> [ro|rw] <SNMP-STATION-IP>
t5 snmp-server contact <LINE>
t5 snmp-server enable [server|traps]
t5 snmp-server host <IP>
t5 snmp-server location <LINE>
Parameters
| community <COMMUNITY-NAME> [ro|rw] |
Defines a public or private community designation. By default, SNMPv2 community
strings on most devices are set to public, for the read-only community string, and
private for the read-write community string.
- <COMMUNITY-NAME> –
Specify the SNMP community name, and configure the access permission for this
community string (used by devices to retrieve or modify information).
- ro – Allows a remote
device to retrieve information only
- rw – Allows a remote device
to retrieve information and modify settings
| <SNMP-STATION-IP> |
Specify the SNMP management station IP address for receiving trap
information |
| contact <LINE> |
Configures the administrator of SNMP trap events for the T5 controller.
- <LINE> – Specify the
administrator‘s name (should not exceed 64 characters).
| enable [server|traps] |
Enables the following:
- server – Enables the SNMP
server. When enabled, the system accepts SNMP management data. This option is
enabled by default.
- traps – Enables SNMP traps.
When enabled, the system generates SNMP traps. This is enabled by default.
| host <IP> |
Configures the T5 SNMP host‘s IP address. The SNMP host receives the SNMP
notifications.
- <IP> – Specify the SNMP
host‘s IP address.
| location <LINE> |
Configures the system location for SNMP traps
- <LINE> – Specify the SNMP
trap location (should not exceed 64 characters).
nx9500-6C8809(config-management-policy-test)#t5 snmp-server community lab rw 192.168.13.7
nx9500-6C8809(config-management-policy-test)#show context
management-policy test
http server
no ssh
Related Commands
| no |
Removes or reverts SNMP server configuration for T5
devices |
