update-source (bgp-neighbor-config)
Allows BGP sessions to use any
operational interface to establish the TCP connection with this neighbor
- Service Platforms — NX9500, NX9600
Syntax
update-source <IPv4>
Parameters
| update-source <IPv4> |
Specify the BGP enabled neighbor‘s IPv4 address. |
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#update-source 192.168.13.1
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
bgp neighbor 192.168.13.99
remote-as 100
advertisement-interval 100
peer-group eBGPPeerGrp1
port 21
strict-capability-match
timers connect 20
timers 20 40
allowas-in 10
attribute-unchanged as-path
capability orf prefix-list both
default-originate
description neighbor "This neighbor is an external AS neighbor"
disable-connected-check
dont-capability-negotiate
ebgp-multihop 20
enforce-multihop
local-as 20 no-prepend
maximum-prefix 400 50 warning-only
next-hop-self
override-capability
passive
password neighbor eBGPneighbor@300
remove-private-as
route-server-client
send-community both
