erase [flash:|nvram:|startup-config|usb1:|usb2:|usb3:|usb4:]
erase [flash:|nvram:|usb1:|usb2:|usb3:|usb4:]
erase startup-config {<HOSTNAME/MAC>|on <DOMAIN-NAME> {containing <SUB-STRING>|
exclude-controllers|exclude-rf-domain-manager|filter <DEVICE-TYPE>}}
flash: |
Erases everything in the device's flash: file |
nvram: |
Erases everything in the device's nvram: file |
startup-config |
Erases the device's startup configuration file. The startup configuration file is used to configure the device when it reboots. |
usb1: |
Erases everything in the device's usb1: file |
usb2: |
Erases everything in the device's usb2: file |
usb3: |
Erases everything in the device's usb3: file |
usb4: |
Erases everything in the device's usb4: file |
| startup-config: | Erases the startup configuration file on a specified device or devices in a specified RF Domain. The specified device(s) are reloaded after the startup configuration file is erased. Use the <HOSTNAME/MAC> or on <DOMAIN-NAME> options to identify the device or RF Domain respectively. Once executed, the configuration file, for the targeted device or for all device(s) in the targeted RF Domain, is also erased from the adopting controller‘s configuration file. They are automatically reloaded once the startup configuration file has been erased. |
| <HOSTNAME/MAC> | Optional. Erases the startup configuration file on the device identified by the <HOSTNAME/MAC> keyword. Specify the device‘s hostname or MAC address. |
| on <DOMAIN-NAME> {containing <SUB-STRING>| exclude-controllers| exclude-rf-domain-manager| filter <DEVICE-TYPE>} | Optional. Erases the startup configuration file
on all devices or specified device(s) in a specified RF Domain
nx9500-6C8809#erase ? cf: Erase everything in cf: flash: Erase everything in flash: nvram: Erase everything in nvram: startup-config Reset configuration to factory default usb1: Erase everything in usb1: usb2: Erase everything in usb2: nx9500-6C8809#
