passpoint-policy
Creates a new passpoint policy and
enters its configuration mode. The passpoint policy implements the Hotspot 2.0 Wi-Fi
Alliance standard, enabling interoperability between clients, infrastructure, and
operators. It makes a portion of the IEEE 802.11u standard mandatory and adds Hotspot 2.0
extensions that allow clients to query a network before actually attempting to join
it.The passpoint policy allows a single or set of Hotspot 2.0 configurations to be
global and referenced by the devices that use it. It is mapped to a WLAN. However, only
primary WLANs on a BSSID will have their passpoint policy configuration
used.
- Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
passpoint-policy <POLICY-NAME>
Parameters
| passpoint-policy <POLICY-NAME> |
Specify the passpoint policy name. If a passpoint policy with the
specified name does not exist, it is created. |
nx9500-6C8809(config)#passpoint-policy test
nx9500-6C8809(config-passpoint-policy-test)#?
Passpoint Policy Mode commands:
3gpp Configure a 3gpp plmn (public land mobile network) id
access-network-type Set the access network type for the passpoint
connection-capability Configure the connection capability for the passpoint
domain-name Add a domain-name for the passpoint
hessid Set a homogeneous ESSID value for the passpoint
internet Advertise the passopint having internet access
ip-address-type Configure the advertised ip-address-type
nai-realm Configure a NAI realm for the passpoint
net-auth-type Add a network authentication type to the passpoint
no Negate a command or set its defaults
operator Add configuration related to the operator of the
passpoint
osu Online signup
roam-consortium Add a roam consortium for the passpoint
venue Set the venue parameters of the passpoint
wan-metrics Set the wan-metrics of the passpoint
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
| no
Removes an existing passpoint policy |
