Configures a Bonjour GW Query Forwarding policy and enters its configuration mode. When created and applied, this policy enables forwarding of Bonjour queries across VLANs.
bonjour-gw-query-forwarding-policy <POLICY-NAME>
| <POLICY-NAME> | Specify the Bonjour GW Query Forwarding policy name. If the
policy does not exist, it is created. In the Bonjour GW Query Forwarding policy configuration mode, specify the ‘from‘ and ‘to‘ VLAN(s). The from-vlans option configures the VLAN(s) that are the source of the Bonjour queries. The to-vlans option configures the destination VLAN(s) that can access the Bonjour queries. To associate a Bonjour GW Query
Forwarding policy with a device or profile, in the
profile/device configuration mode, execute the
use > bonjour-gw-query-forwarding-policy > <POLICY-NAME>command. For more information, see use (profile/device-config-mode-commands). |
nx9500-6C8809(config)#bonjour-gw-query-forwarding-policy test nx9500-6C8809(config-bonjour-gw-query-forwarding-policy-test)#? (config-bonjour-gw-query-forwarding-policy) commands: forward-bonjour-query Forwards bonjour query across vlans no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-bonjour-gw-query-forwarding-policy-test)#
| no | Removes an existing Bonjour GW Query Forwarding policy |
