Enables the sending of the default route to BGP neighbors. It also allows the configuration of the default route. When enabled and configured, local BGP routers send the default route 0.0.0.0 (or a route map specified route) to its neighbor for use as the default route.
default-originate {route-map <BGP-ROUTE-MAP-NAME>}
default-originate
Enables default originate on this BGP neighbor. This
option is disabled by default.
Note: If no route-map is specified, the default route 0.0.0.0 is
sent.
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#default-originate
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context bgp neighbor 192.168.13.99 advertisement-interval 100 allowas-in 10 attribute-unchanged as-path capability orf prefix-list both default-originate nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#
| no (bgp-neighbor-config) | Disables sending of the default route to BGP neighbors |
