dhcpv6-pool (dhcpv6-server-policy-config)
Configures a DHCPv6 server address pool
and enters its configuration mode. A DHCPv6 IPv6 pool is a resource from which IPv6 formatted
addresses can be issued on DHCPv6 client requests. IPv6 addresses are composed of eight groups
of four hexadecimal digits separated by colons.
- Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
dhcpv6-pool <DHPCv6-POOL-NAME>
Parameters
dhcpv6-pool <DHCPv6-POOL-NAME>
| <DHCPv6-POOL-NAME> |
Creates a DHCPv6 server address pool
- <POOL-NAME> – Specify a name that appropriately identifies this DHCPv6
address pool. If the pool does not exist, it is created. The pool name cannot be
modified as part of the edit process. However, an obsolete address pool can be
deleted.
nx9500-6C8809(config-dhcpv6-server-policy-test)#dhcpv6-pool DHCPv6Pool1
nx9500-6C8809(config-dhcpv6-server-policy-test-pool-DHCPv6Pool1)#?
DHCPv6 pool Mode commands:
dns-server DNS Servers
domain-name Configure domain-name
network Network on which DHCPv6 server will be deployed
no Negate a command or set its defaults
option Raw DHCPv6 options
refresh-time Upper limit specifying the timer for which client should wait
before refreshing information
sip SIP server options
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
nx9500-6C8809(config-dhcpv6-server-policy-test)#show context
dhcpv6-server-policy test
network 2002::/64
domain-name TechPubs
sip domain-name TechPubsSIP
dns-server 2002::1
Related Commands
The following table summarizes the DHCPv6 Pool configuration mode commands
