Configures a captive portal based filter for this user-defined role. A captive portal is a guest access policy that provides temporary and restrictive access to the wireless network. When applied to a WLAN, a captive portal policy ensures secure guest access.
This command defines user-defined role filters based on a wireless client‘s state of authentication.
captive-portal authentication-state [any|post-login|pre-login]
| authentication-state | Defines the authentication state of a client connecting to a captive portal |
| any | Specifies any authentication state (authenticated
                        and pending authentication). This is the default setting. This option makes no distinction on whether authentication is conducted before or after the wireless client has logged in. |
| post-login | Specifies authentication is completed successfully This option requires the wireless client to share authentication credentials after logging into the managed network. |
| pre-login | Specifies authentication is pending This option enables captive portal client authentication before the client is logged into the controller. |
nx9500-6C8809(config-role-policy-test-user-role-testing)#captive-portal authentication-state pre-login
         nx9500-6C8809(config-role-policy-test-user-role-testing)#show context user-role testing precedence 10 authentication-type eq kerberos ap-location contains office captive-portal authentication-state pre-login nx9500-6C8809(config-role-policy-test-user-role-testing)#
| no | Removes the captive portal based role filter settings |
