Dot.1x supplicant configuration is supported on the following platforms:
Dot.1x authenticator configuration is supported on the following platforms:show dot1x {all|interface|on}
show dot1x {all {on <DEVICE-NAME>}|on <DEVICE-NAME>}
show dot1x {interface [<INTERFACE-NAME>|ge <1-4>|port-channel <1-2>} {on <DEVICE-NAME>}
| dot1x all {on <DEVICE-NAME>} | Optional. Displays dot1x information for all interfaces
| dot1x {on <DEVICE-NAME>} |
Optional. Displays dot1x information for interfaces on a specified device
show dot1x {interface [<INTERFACE-NAME>|ge <1-4>|port-channel <1-2>]} {on <DEVICE-NAME>}
| dot1x interface | Optional. Displays dot1x information for a specified interface or interface type |
| <INTERFACE-NAME> | Displays dot1x information for the layer 2 (Ethernet port) interface specified by the <INTERFACE-NAME> parameter |
| ge <1-4> | Displays dot1x for a specified GigabitEthernet
interface
| port-channel <1-2> | Displays dot1x for a specified port channel interface
| on <DEVICE-NAME> | The following keywords are common to all of the above parameters:
ap8432-070235>show dot1x all 802.1X information ------------------------------ SysAuthControl : disabled Guest-Vlan : disabled AAA-Policy : none Holdtime : 60 802.1X information for interface GE1 -------------------------------------- Supplicant MAC N/A Auth SM State : FORCE AUTHORIZED Bend SM State : REQUEST Port Status : AUTHORIZED Host Mode : SINGLE Auth Vlan : None Guest Vlan : None 802.1X information for interface GE2 -------------------------------------- Supplicant MAC N/A Auth SM State : FORCE AUTHORIZED Bend SM State : REQUEST Port Status : AUTHORIZED Host Mode : SINGLE Auth Vlan : None Guest Vlan : None ap8432-070235>
