network
Assigns networks to specified areas
(defines the OSPF interfaces and their associated area IDs)
- Access Points — AP410i/e, AP460i/e,
AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432,
AP8533
Syntax
network <IP/M> area [<0-4294967295>|<IP>]
Parameters
| <IP/M> |
Specifies an OSPF network address/mask value. Defines networks (IP
addresses and mask) participating in OSPF. |
| area [<0-4294967295>|<IP>] |
Specifies an OSPF area, associated with the OSPF address range, in one
of the following formats:
- <0-4294967295> –
Specifies a 32 bit OSPF area ID from 0 - 4294967295
- <IP> – Defines
an OSPF area ID in the form of an IPv4 address
nx9500-6C8809(config-profile default-ap8533-router-ospf)#network 1.2.3.0/24 area 4.5.6.7
nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context
router ospf
area 0.0.0.4
auto-cost reference-bandwidth 1
default-information originate metric 1 metric-type 2
ip default-gateway priority 1
