Negates a command or sets its default. Removes or modifies the RADIUS group policy settings. When used in the config RADIUS group mode, the no command removes or modifies the following settings: access type, access days, role type, VLAN ID, and SSID.
no [guest|policy|rate-limit]
no guest
no policy [access|day|inactivity-timeout|role|session-time|ssid|time|vlan]
no policy access [all|console|ssh|telnet|web]
no policy day [all|fr|mo|sa|su|th|tu|we|weekdays]
no policy session-time
no policy ssid [<SSID>|all]
no policy [inactivity-timeout|role|time|vlan]
no rate-limit [from-air|to-air]
no <PARAMETERS>
no <PARAMETERS> |
Negates a command or sets its default. Removes or modifies the RADIUS group policy settings. When used in the config RADIUS group mode, the no command removes or modifies the following settings: access type, access days, role type, VLAN ID, and SSID. |
The following example shows the RADIUS guest group ‘test‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-radius-group-test)#show context radius-group test guest policy vlan 1 policy ssid test policy day mo policy day tu policy day we policy day th policy day fr policy day sa policy day su rate-limit to-air 200 policy time start 13:30 end 17:30 nx9500-6C8809(config-radius-group-test)#
nx9500-6C8809(config-radius-group-test)#no guest
nx9500-6C8809(config-radius-group-test)#no rate-limit to-air
nx9500-6C8809(config-radius-group-test)#no policy day all
The following example shows the RADIUS guest group ‘test‘ settings after the ‘no‘ commands are executed:
nx9500-6C8809(config-radius-group-test)#show context radius-group test policy vlan 1 policy ssid test policy time start 13:30 end 17:30 nx9500-6C8809(config-radius-group-test)#
