gre
Profile Config Commands
The following table summarizes commands that allow you to enter the GRE configuration mode:
Command Description
gre Enables GRE tunneling on a profile/device. Use this command to enter GRE configuration mode, and to create up to 1000 GRE tunnels. Use this command to modify an existing GRE tunnel‘s settings.
gre-config-instance Summarizes GRE tunnel configuration mode commands
