<DEVICE>(config)#wlan <WLAN-NAME>
| Command | Description |
Configures the IEEE 802.11v standard parameters on this WLAN |
| accounting (wlan-config-mode) | Defines a WLAN's accounting settings |
| acl | Defines the actions based on an ACL rule configuration |
| answer-broadcast-probes | Allows a WLAN to respond to probes for broadcast ESS |
| assoc-response | Configures a minimum receive signal strength indication (RSSI) value, below which the WLAN does not send a response to a client‘s association request |
| association-list | Attaches an existing global association list to a WLAN |
| authentication-type | Sets a WLAN's authentication type |
| bridging-mode | Configures how packets are bridged to/from this WLAN |
| broadcast-dhcp | Configures broadcast DHCP packet handling |
| broadcast-ssid | Advertises a WLAN's SSID in beacons |
| captive-portal-enforcement | Configures a WLAN's captive portal enforcement |
| client-access | Enables WLAN client access (normal data operations) |
| client-client-communication | Allows the switching of frames from one wireless client to another on a WLAN |
| client-load-balancing | Enables load balancing of WLAN clients |
| controller-assisted-mobility | Enables controller assisted mobility to determine wireless clients' VLAN assignment |
| data-rates | Specifies the 802.11 rates supported on the WLAN |
| description | Sets a WLAN's description |
| downstream-group-addressed-forwarding | Enables forwarding of downstream packets addressed to a group |
| dpi | Enables extraction of metadata flows on the WLAN |
| dynamic-vlan-assignment | Configures dynamic VLAN assignment on this WLAN |
| eap-types | Configures client access based on eap-type used for authentication |
| encryption-type | Sets the WLAN's encryption type |
| enforce-dhcp | Drops packets from clients with a static IP address |
| fast-bss-transition | Configures support for 802.11r fast BSS transition on a WLAN |
| http-analyze | Enables HTTP URL analysis on the WLAN |
| ip (wlan-config-mode) | Configures IPv4 settings on this WLAN |
| ipv6 (wlan-config-mode) | Configures IPv6 settings on this WLAN |
| kerberos | Configures Kerberos authentication parameters |
| mac-authentication | Configures MAC authentication parameters |
| nsight | Enables retention of guest client history in the NSight database |
| opendns | Configures the device ID, which is embedded in each DNS query packet going out from an access point, wireless controller, or service platform to the OpenDNS server |
| owe-companion | Configures the name of the WLAN companion for the specified WLAN. |
| protected-mgmt-frames | Enables and configures the WLAN's frame protection mode and security association |
| proxy-arp-mode | Enables the proxy ARP mode for ARP requests |
| proxy-nd-mode | Configures the proxy ND mode for this WLAN member clients as either strict or dynamic |
| qos-map | Enables support for 802.11u QoS map element and frames |
| radio-resource-measurement | Enables support for 802.11k radio resource measurement |
| radius | Configures RADIUS parameters |
| registration | Configures settings enabling dynamic registration of devices. Use this command to specify the mode of registration and to configure corresponding parameters. |
| relay-agent | Enables support for DHCP relay agent information (option 82) feature on this WLAN |
| service (wlan-config-context) | Invokes service commands applicable in the WLAN configuration mode |
| shutdown | Shuts down a WLAN |
| ssid | Configures the WLAN's SSID |
| t5-client-isolation | Disallows clients connecting to the WLAN to communicate with one another |
| t5-security | Configures T5 PowerBroadband security settings |
| time-based-access | Configures time-based client access |
| use (wlan-config-mode) | Defines WLAN mode configuration settings |
| vlan | Assigns a VLAN for the WLAN |
| vlan-pool-member | Adds a member VLAN to the pool of VLANs for a WLAN |
| wep128 | Configures WEP128 parameters |
| wep64 | Configures WEP64 parameters |
| wing-extensions | Enables support for WiNG specific extensions to 802.11 |
| wireless-client | Configures the transmit power for wireless clients transmission |
| wpa-wpa2 | Modifies TKIP and CCMP (WPA/WPA2) related parameters |
| no (wlan-config-mode) | Negates a command or reverts settings to their default |
