Configures this group as a guest (non-management) group. A guest user group has temporary permissions to the controller‘s local RADIUS server. You can configure multiple guest user groups, each having a unique set of settings. Guest user groups cannot be made management groups with access and role permissions.
Guest users and policies are used for captive portal authorization to the network.
guest
None
nx9500-6C8809(config-radius-group-test)#guest
nx9500-6C8809(config-radius-group-test)#show context radius-group test guest nx9500-6C8809(config-radius-group-test)#
| no |
Makes this group a non-guest group |
