Use the guest management policy commands to configure parameters, such as E-mail host and SMS gateway along with the credentials required for sending pass code to guest via e-mail and SMS. You can configure up to 32 different guest management policies. Each guest management policy allows you to configure the SMS gateway, SMS message body, E-mail SMTP server, E-mail subject contents, and E-mail message body. Although, at any point-in-time, multiple guest management policies may exist, only one guest management policy can be active per device.
Guest registration is supported only on the NX9500 and NX7500 series service platforms. However, the number of user identity entries supported on each varies. It is 2 million and 1 million user-identity entries for the NX9500 and NX7500 model service platforms respectively.
guest-management <POLICY-NAME>
| <POLICY-NAME> | Specify the guest management policy name. If the policy does not exist, it is created. |
nx9500-6C8809(config)#guest-management guest nx9500-6C8809(config-guest-management-guest)#? Guest Management Mode commands: email Email guest-notification configuration guest-database-backup Configure guest-database-backup parameters guest-database-export Configure guest-database-export parameters no Negate a command or set its defaults sms SMS guest-notification configuration sms-over-smtp Sms-over-smtp configuration to email sms gateway address clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-guest-management-guest)#
| no | Removes an existing guest management policy |
