interface-config-radio-instance
Configures RIFS (Reduced Interframe Spacing) parameters on this radio
This value determines whether interframe spacing is applied to access point transmitted or received packets, both, or none. Inter-frame spacing is the interval between two consecutive Ethernet frames that enable a brief recovery between packets and allow target devices to prepare for the reception of the next packet.
rifs [none|rx-only|tx-only|tx-rx]
| rifs | Configures RIFS parameters |
| none | Disables support for RIFS. Consider setting the value to None for high-priority traffic to reduce packet delay. |
| rx-only | Supports RIFS possession only |
| tx-only | Supports RIFS transmission only |
| tx-rx | Supports both RIFS transmission and possession (default setting) |
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#rifs tx-only nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 rf-mode sensor placement outdoor mesh client off-channel-scan channel-list 2.4GHz 1 guard-interval long aggregation ampdu tx-only rifs tx-only aeroscout forward ekahau forward ip 172.16.10.1 port 3 non-unicast tx-rate bss 1 dynamic-all non-unicast tx-rate bss 2 highest-basic non-unicast tx-rate bss 3 highest-basic non-unicast tx-rate bss 4 highest-basic --More-- nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
| no (radio-interface-config-command) | Disables radio‘s RIFS parameters |
