static-binding (dhcpv4-pool-config)
Configures static IP address information for a particular device. Static address binding is executed on the device‘s hostname, client identifier, or MAC address. Static bindings allow the configuration of client parameters, such as DHCP server, DNS server, default routers, fixed IP address, etc.
A static address binding is a collection of configuration parameters, including an IP address, associated with, or bound to, a DHCP client. Bindings are managed by DHCP servers. DHCP bindings automatically map a device MAC address to an IP address using a pool of DHCP supplied addresses. Static bindings assign IP addresses without creating numerous host pools with manual bindings. Static host bindings use a text file the DHCP server reads. It eliminates the need for a lengthy configuration file and reduces the space required to maintain address pools.
Syntax
static-binding [client-identifier <CLIENT>|hardware-address <MAC>]
Parameters
Enables a static binding configuration for a client based on its client identifier (as provided by DHCP option 61 and its key value)
  • <CLIENT> – Specify the client identifier (DHCP option 61).
Enables a static binding configuration for a client based on its MAC address
  • <MAC> – Specify the MAC address of the client.
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#static-binding client-identifier test
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#show context
 dhcp-pool testPool
  address 192.168.13.4 class dhcpclass1
  update dns override
  ddns server 192.168.13.9
  ddns multiple-user-class
  excluded-address range 192.168.13.25 192.168.13.28
  netbios-node-type b-node
  dns-server 192.168.13.19
  netbios-name-server 192.168.13.25
  option option1 157.235.208.80
  respond-via-unicast
  static-route 192.168.13.0/24 192.168.13.7
rfs4000-229D58(config-dhcp-policy-test-pool-testPool-binding-test)#?
DHCP static binding Mode commands:
  bootfile             Boot file name
  client-name          Client name
  default-router       Default routers
  dns-server           DNS Servers
  domain-name          Configure domain-name
  ip-address           Fixed IP address for host
  netbios-name-server  NetBIOS (WINS) name servers
  netbios-node-type    NetBIOS node type
  next-server          Next server in boot process
  no                   Negate a command or set its defaults
  option               Raw DHCP options
  respond-via-unicast  Send DHCP offer and DHCP Ack as unicast messages
  static-route         Add static routes to be installed on dhcp clients
  clrscr               Clears the display screen
  commit               Commit all changes made in this session
  do                   Run commands from Exec mode
  end                  End current mode and change to EXEC mode
  exit                 End current mode and down to previous mode
  help                 Description of the interactive help system
  revert               Revert changes
  service              Service Commands
  show                 Show running system information
  write                Write running configuration to memory or terminal
nx9500-6C8809(config-dhcp-policy-test-pool-pool1)#static-binding hardware-address 11-22-33-44-55-66
nx9500-6C8809(config-dhcp-policy-test-pool-pool1-binding-11-22-33-44-55-66)#?
The following table summarizes the DHCPv4-User-Pool Static Binding commands:
Table 1. DHCPv4-User-Pool Static-Binding Config Mode Commands
Command
Description
bootfile (dhcpv4-pool-static-binding)
Assigns a Bootfile name for the DHCP configuration on the network pool
client-name (dhcpv4-pool-static-binding)
Configures a client name
default-router (dhcpv4-pool-static-binding)
Configures default router or gateway IP address
dns-server (dhcpv4-pool-static-binding)
Sets the DNS server‘s IP address available to all DHCP clients connected to the DHCP pool
domain-name (dhcpv4-pool-static-binding)
Sets the network pool‘s domain name
ip-address (dhcpv4-pool-static-binding)
Configures a host‘s fixed IP address
netbios-name-server (dhcpv4-pool-static-binding)
Configures a NetBIOS (WINS) name server IP address
netbios-node-type (dhcpv4-pool-static-binding)
Defines the NetBIOS node type
next-server (dhcpv4-pool-static-binding)
Specifies the next server used in the boot process
option (dhcpv4-pool-static-binding)
Configures raw DHCP options
respond-via-unicast (dhcpv4-pool-static-binding)
Sends a DHCP offer and DHCP Ack as unicast messages
static-route (dhcpv4-pool-static-binding)
Adds static routes installed on DHCP clients
no (dhcpv4-pool-static-binding) Negates or reverts to default this DHCP Pool's static binding settings
