The following table summarizes the client-identity configuration mode commands:
| Command | Description |
| dhcp | Configures the DHCP option match criteria for device fingerprinting |
| dhcp-match-message-type | Configures the DHCP message type for device fingerprinting |
| no (client-identity-config-mode) | Removes the DHCP option (used for client identification) configurations |
